  • Bambe 45 posts 66 karma points
    Mar 16, 2011 @ 11:45
    Bambe
    TinyMCE add some buttons fail
    hi,
    I purchased two TinyMCE plugins is "MCFileManager" and "MCImageManager" for .NET
    and following the instruction to install them
    the buttons are successfully appears on TinyMCE tool bar ...
    but I press the buttons, the popup window says:
    Page not found
    No umbraco document matches the url 'http://192.168.1.131:470/umbraco_client/tinymce3/plugins/filemanager/default.aspx?type=fm&page=index.html'
    umbraco tried this to match it using this xpath query'/root/*/* [@urlName = "umbraco_client"]/* [@urlName = "tinymce3"]/* [@urlName = "plugins"]/* [@urlName = "filemanager"]/* [@urlName = "default"]')
    This page can be replaced with a custom 404 page by adding the id of the umbraco document to show as 404 page in the /config/umbracoSettings.config file. Just add the id to the '/settings/content/errors/error404' element.
    For more information, visit information about custom 404 on the umbraco website.
    This page is intentionally left ugly ;-)
    should I open or allow something??
    it seems like the Umbraco not allow me to access the file...
    the plugins I think it must somebody to purchase it from TinyMCE so I ask here...
    I hope someone to solve my problem :(
    thanks a lot :)
    Regards,
    Bambe
  • Anders Rørvik 25 posts 47 karma points
    Mar 16, 2011 @ 21:29
    Anders Rørvik
    Hi Bambe!
    In your web.config file you have the ability to specific certain urls and paths which should be ignored by Umbraco. Look for the umbracoReservedUrls section, and add your url there.
    Mar 17, 2011 @ 09:59
    Bambe
    Hi Anders,
    I'm very very thanks for your help!
    your tips are succesfully solve my problem
    but my solution is add '~/umbraco_client/' in umbracoReservedPaths value
    not use umbracoReservedUrls :)
    Thanks for your help :)
    Regards,
    Bambe
