Changing permissions - Multiple controls with the same ID '4_a' were found
Hi, I have an Umbraco 4.5.1 website that was upgraded a long time ago from 4.0.x (so long ago I can't remember what exact version). There has been lots of customisations to the site both front end and backend. I have just noticed that if I try to change the permission on some nodes I get the following errror. I do seem to have the Google Analytics package installed still but I don't know how to get rid of it because it is not showing in the Installed packages list. Could this be the problem or is it something else, please can someone help. This is the error:
Multiple controls with the same ID '4_a' were found. FindControl requires that controls have unique IDs.
Exception Details: System.Web.HttpException: Multiple controls with the same ID '4_a' were found. FindControl requires that controls have unique IDs.
Source Error:
Stack Trace:
[HttpException (0x80004005): Multiple controls with the same ID '4_a' were found. FindControl requires that controls have unique IDs.]
System.Web.UI.Control.FillNamedControlsTable(Control namingContainer, ControlCollection controls) +11252276
System.Web.UI.Control.FillNamedControlsTable(Control namingContainer, ControlCollection controls) +317
System.Web.UI.Control.FindControl(String id, Int32 pathOffset) +145
System.Web.UI.Page.ProcessPostData(NameValueCollection postData, Boolean fBeforeLoad) +311
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2637
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.1
No I didn't manage to solve it, the only packages that are showing in the list are:
Twitter for Umbraco ASP.net Security Vunerability Patch
But I can see that the Google Analytics package is installed because it is showing as one of the sections. I can try removing the two packages listed above but I have no way of removing the Google Analytics package unless someone has a list of items I need to manually remove from the website.
Hi Trevor
It's a bit hard to figure out what is going on. Did you manage to solve this?
If not...how many packages and what packages do you have installed? What happens if you remove them? (If you're able to do so).
Twitter for Umbraco
