  • Eric Herlitz 97 posts 129 karma points
    Mar 17, 2011 @ 16:11
    Eric Herlitz
    Zip Upload + Umbraco 4.7 returns funky errors
    I get this when using Zip Upload and Umbraco 4.7
    Multiple controls with the same ID 'dashBoardZipUpload' were found. FindControl requires that controls have unique IDs.
    Any ideas what to do to get zip upload working with umbraco 4.7?
    Mar 17, 2011 @ 16:41
    Tom Fulton
    This doesn't really answer your question, but I believe ZipUpload was removed in 4.7 and replaced with Desktop Media Uploader.  I wonder if it didn't get removed from your dashboard.config?
  • Petr Snobelt 923 posts 1535 karma points
    Mar 18, 2011 @ 06:44
    Petr Snobelt
    Can someone confirm that zip upload it is removed. If it is it should be noted in release docs.
    BTW I prefer zipupload, it don't need any aditional components installed.
    Petr
    Mar 18, 2011 @ 12:38
    Tom Fulton
    I can pretty much confirm it's gone, on a fresh install of 4.7 there is no ZipUpload option and DMU is in it's place.  Also that looks to be the case according to this changeset:
    6e569de7740a
    by matt
    Feb 5 at
    7:21 AM
    6 4.6.1-dmu-wip Added DMU Flex source
    Changed all TheOutfield namesspaces to Umbraco
    Added DMU dasboards
    Removed ZipUpload dashboards
    Added air mimetype to web.config
    There may still be a way to use it though, but I'm not sure.  Might have to retrieve the files from an older release and check your dashboard.config.  Sorry!
