  • jliwkwl 29 posts 20 karma points
    Jan 09, 2009 @ 09:14
    jliwkwl
    Copy from testserver to liveserver?
    Hi!
    I've got umbraco3 running on a test- and a liveserver. When I want to update the liveserver I copy everything from the testserver (database and umbraco files).
    Is there a other way to do that so I don't have to copy everything?
  • Ruben Verborgh 379 posts 30 karma points
    Jan 10, 2009 @ 15:21
    Ruben Verborgh
    Hi there,
    A commercial alternative is available. It's called Courier and it comes with Umbraco Pro.
    I don't see any other free options at the moment.
    Ruben
  • umbracosathish 2 posts 20 karma points
    Jan 19, 2009 @ 11:59
    umbracosathish
    If its css or javascript, then you can copy that files alone to your liveserver not entire stuff.
    If its document type then export and import that alone to the liveserver.
    If you are doing changes to xslt then copy that particular files alone to the liveserver.
    I think this helps you littlebit..
    Sathish
  • Volodymyr Muzyka 11 posts 20 karma points
    Jan 20, 2009 @ 11:28
    Volodymyr Muzyka
    what about packages? they looks OK for most cases. you just create package in "source" and do uninstall/install at live. or.. you just create "update" packages.. which contains only new content.
  • Xirius 1 post 20 karma points
    Jan 21, 2009 @ 19:59
    Xirius
    You could try this: http://www.codeplex.com/UmbracoExportTool
    Hav not tried it my self tho.
