  • Kennet Guldager 5 posts 26 karma points
    Mar 18, 2011 @ 11:49
    Kennet Guldager
    Insert Link problem Tiny MCE 4.7 and 4.6.1
    hi
    When i'm trying to insert link in Tiny MCE the "insert/edit link" dialog is missing the Target and Anchor controls.
     The result is no link is created in the text, when "insert" buttom is clicked. The dialog window dosent close, and the URL and Title fields are blanked but no link is created in text.
    Had the problem in version 4.6.1,  an update to 4.7 final didnt fix the problem
    Tested in chrome, IE 8, firefox - same behavor
    Any ideas?
    Mar 19, 2011 @ 08:07
    Hi Kenneth
    This is perhaps a long shot...but are you sure permissions have been set correctly? It indeed seems like at very odd behaviour.
    Mar 22, 2011 @ 15:04
    Kennet Guldager
    I think the permissions are correct. compared to working sites runing 4.5.2
    insert anchor, image, custom characters and table, all work, but not insert link
    this is output for chrome dev tools console
    1. Uncaught TypeError: Cannot set property 'innerHTML' of null
      1. tinyMCEPopup._onDOMLoadedDependencyHandler.axd:302
    any suggestions?
