  • Scott Hugh Alexandar Petersen 349 posts 164 karma points
    Jan 12, 2009 @ 12:00
    Embedded media and w3c standard
    Hey guys,
    I've got 2 questions:
    1. When I use the Insert / edit embedded media button in the rich text editor and then validate my page afterwards with http://validator.w3.org/ then it gives me 5 errors (inserting a flash file).
    So what am I to do? Remove the Insert / edit embedded media button and create macros or what do you suggest?
    2. Another thing is that the swf file does not resize to the size that I want.. Why not?
    Thank you
  • Ruben Verborgh 379 posts 30 karma points
    Jan 14, 2009 @ 14:51
    Ruben Verborgh
    Hi Scott,
    For Flash, I use an XSLT macro which takes 3 parameters: filename, width, height. This macro then outputs a script reference at run time (SWFObject) which displays the Flash object. Validates perfectly.
    Ruben
    Jan 14, 2009 @ 15:08
    Yeah I have one of them as well - but as it is part of the RichTextEditor I thought it might be much more convenient to do it that way for a user.
    Thanks for your reply.
    Jan 15, 2009 @ 10:18
    I actually found a way - as this is generated in JS in the config file, under plugins then I can just edit that text so it outputs the script that I want.
    Thank you all.
