  • dalecam 20 posts 20 karma points
    Jan 19, 2009 @ 00:14
    dalecam
    What does Recursive mean in macro properties?
    If you go to add a macro in v4 of umbraco one of the options specifies 'Recursive'. What does this mean and what does it do?
    Thanks in advance!
    Dale
  • bob baty-barr 1180 posts 1294 karma points MVP
    Jan 19, 2009 @ 02:49
    bob baty-barr
    macro or pageField???
    in a pageField, the recursive property means that it will 'bubble up' the node structure until it finds a node with a value on that property.
    i was just experimenting with using a pageField as a parameter when inserting a macro and utilizing recursion...
    here is a great little documentation about macro parameters...
    macro recursion
    hope that info is helpful.
    Jan 19, 2009 @ 03:30
    dalecam
    Hi bob(i assume?)
    Thanks for your reply. Yes sorry i did mean a page feild, and your explanation was fantastic. Thank you - really appreciated.
    Dale
