    Mar 22, 2011 @ 15:54
    Anthony Candaele
    problem with Blog4Umbraco and Cog Flexible Navigation
    As you can see in the screenshot I'm having a problem with the Cog Flexible Navgigation and blogposts (Blog4Umbraco)
    I found the problem in the xslt-code of the Cog Flexible Navigation xslt code:
    <!--set the innerText for the a element-->
                <xsl:if test="string(./pageTitle/text()) = ''">
                </xsl:if>
    As a blogpost doesn't have a pageTitle property, the nodeName attribute is rendered twice.
    So I could solve this by adding a condition to the if-statement to also exclude BlogPost elements, only my Xslt knowledge is not that good.
    Does someone know how I can add an exclude condition for BlogPost elements to the if-statement?
    Thanks for your help,
    Anthony
    Belgium
