Hello i just wondered why my sortOrder xslt does not work. Now i got it.
If i edit the sort order via umbraco backend and reload the frontend it looks like the cache is not being refreshed.
If I touch web.config and reload the site it works.
Is there an easy way to recache the site after changing the sorting of the media items?
What version of Umbraco are you using? I found this thread and related workitem that says it was resolved. A quick test on a 4.7 install it seems to be working properly.
i use Umbraco 4.5 and it seems the site is only refreshed if i open web.config and save it
The entire site or just media? If just media it should be fixed in 4.7
i think it is just media. I will try to upgrade but i do not know how hard this would be
clear cache problem on sorting media items
