I'm using v4-RC2 and want to display the label for the RTE to users. I believe this happens automatically when there are two or more RTE's on the same tab, but in this case I have only one RTE on the tab.
More specifically, I want to display the "Description" text/icon associated with the RTE in the docType, just as happens with the other docType properties.
I've got the following setting in the /config/umbracoSettings.config file:[code][/code]
I see the question mark icons for other properties, but how can I display it for a single RTE?
If i'm understanding this correctly then what you want to do is open up the Developer tab, expand the Data Types section and select the Richtext Editor. Buried deep at the bottom of the Settings section is a 'Show label' checkbox. Tick this and save and you should now have the Name and description text or icon shown against all Richtext text editors.
How to display Property Context Help for an RTE?
cheers,
doug.
