Ive got a banner xslt script which shows a banner on a specific page.
Now i want to add a property called "Show only once"
If this property is set to true the banner should only be shown once.
I think the best method to do this is to store a cookie and look if the cookie still exists
Anybody any idea how to handle this?
You can retrieve the cookie in XSLT using
<xsl:value-of select="umbraco.library:RequestCookies('nameOfCookie')"/>
Rich
Hi Dominik
You could also consider using the jquery.Cookie plugin to create the cookie - read more about the plugin usage here: http://www.electrictoolbox.com/jquery-cookies/
yes i got it but how can i get any umbraco media type id into this cookie ?
i tryed the following:
$.cookie("banner-layer", "<xsl:value-of select="$mediaNode" />", { expires: 7 });
But the cookie value is null
ok it works now - sorry
Happy to hear you got it solved.
Are you using the xslt extension to read the cookie or do you use the cookie plugin for that? (Being curious :))
I read and store the cookie via xslt an jquery inside the XSLT and it works great
Thanks for your help
Store cookie in XSLT
<xsl:value-of select="umbraco.library:RequestCookies('nameOfCookie')"/>Rich
Hi Dominik
Hi Dominik
