  • Robin Nicholl 137 posts 277 karma points
    Mar 24, 2011 @ 17:33
    Robin Nicholl
    4.7 - Business Starter Kit - Blog problems (loads)
    Trying to create a site based on the Business Starter Kit that can be installed with 4.7 – but there are loads of problems. I've managed to fix a couple (to do with archive display) with the help of other people's posts on this forum: most relating to misnamed alias references in the xslt. But I seem to encounter a problem with almost every feature:
    • Adding BlogArchive to the sidebar: lists 6 months, but shows 0 posts for all, despite the fact that there are plenty. I've corrected 'umbDateFolder' in umbBlogArchive.xslt to just 'DateFolder, but no luck.
    • Comments don't seem to work in any useful way. I can post a comment, but it just appears with no sort of moderation at all. If I try to mark it as spam, delete it, or delete all in the Comments tab of the Content node… nothing happens at all. (Well, if I try t delete it I get asked if I'm sure, but then the comment remains).
    At this rate I'll have to turn to WordPress instead – which I'd rather not do, as it's fiddly to customise, and this project is only partly blog… and I like Umbraco!
    Any help would be appreciated.
    Mar 24, 2011 @ 17:36
    Rich Green
    I installed this under 4.7 morning too, got loads of errors...
    I would look at Blog4Umbraco http://our.umbraco.org/projects/collaboration/blog-4-umbraco if you're looking for a featured blog
    Rich
  • Joshua 2 posts 22 karma points
    Dec 19, 2012 @ 08:58
    Joshua
    If you desire to do inspection of your several products or any business then you can hire inspection team any time in Canada, Pakistan, India, Bangladesh, China and Asia. It is always helpful for you.
    http://asiatextileinspections.com/
