  • dominik 711 posts 733 karma points
    Mar 25, 2011 @ 14:22
    dominik
    Set default value for true/false property
    Is there a way to set a property (true/false parameter) default to checked (1)?
  • kows 81 posts 151 karma points c-trib
    Mar 25, 2011 @ 14:35
    kows
    rename your property :p
    we always name our property so our default value should be false..
    like umbracoNaviHide to hide from navigation.
    Mar 25, 2011 @ 14:44
    dominik
    I got the property on more than one type so renaming is not a good solution :-)
    I just want to set this default "checked" for one of the types - is there no possibility for it?
    Mar 25, 2011 @ 15:22
    Tom Fulton
    Not with the built in True/False datatype.  But there is a datatype in uComponents called ToggleBox that allows you to set a default value (on/off) that you could use alternatively.
    -Tom
    Mar 25, 2011 @ 15:29
    dominik
    Ok so i will try to use this
  • Fergus Davidson 309 posts 588 karma points
    Mar 25, 2011 @ 16:32
    Fergus Davidson
    check out the 'Standard Values' package - it lets you set default text etc, including tickbox states for any document type.
    http://our.umbraco.org/projects/developer-tools/standard-values-in-umbraco
    works with previous/ lastest versions
