I can replicate this on umbraco v 3.0.6 (Assembly version: 1.0.3050.25839).
Perhaps it has been resolved in version 4? Too bad I can't upgrade since the site in question is using Lefteris Multiple Media Picker and it's not fully compatible with Umbraco 4. :-(
Unpublish deletes media references
I have noticed that if i unpublish a page that uses a media picker data type, all references to picked media are removed from the page.
Is this a bug? Is there a way to stop it happening?
[quote=danimal]I have noticed that if i unpublish a page that uses a media picker data type, all references to picked media are removed from the page.
Thanks[/quote]
Witch version are you using?
Please report this bug in codeplex.com/umbraco
/jesper
Version 3.0.5 - i will report now. can you replicate it?
