  • dominik 711 posts 733 karma points
    Mar 28, 2011 @ 13:10
    dominik
    Slider with pagination (jQuery)
    hello,
    Ive got the following scenario:
    I just want to add a simple jQuery slider with Repeatable Custom Content - Now i need to increase the value of the pagination for each item.
    Here is my xslt:
    <xsl:template name="pagination">
      <div class="pagination">
        <ul>
          <xsl:for-each select="$currentPage/self::* //homeSlider/items/item">
            <li><a href="#">1</a></li>
          </xsl:for-each>
          </ul>
    </xsl:template>
    <xsl:template match="/">
    <!-- start writing XSLT -->
      <div class="home-header">
            <div class="content">
              <xsl:call-template name="pagination"></xsl:call-template>
              <div class="text">
                <h5><xsl:value-of select="./data [@alias = 'homeHeadline']"/></h5>
                <xsl:value-of select="./data [@alias = 'homeSubHeadline']"/>
    </xsl:for-each>
    </xsl:template>
    The Value of the <li> Element should be dynamic 1 for the first slide and 2 for the second slide
  • Pasang Tamang 258 posts 458 karma points
    Mar 28, 2011 @ 13:21
    Pasang Tamang
    In this case one good option is using sort order.
    <li><a href="#"><xsl:value-of select="@sortOrder"/></a></li>
    Mar 28, 2011 @ 13:25
    dominik
    if I use this the value is empty
    Mar 28, 2011 @ 13:27
    Pasang Tamang
    Value empty means @sortOrder?
    Mar 28, 2011 @ 13:28
    dominik
    Yes i get no value for @sortOrder it is just empty and not "1" "2"
    Mar 28, 2011 @ 13:31
    Pasang Tamang
    Actually @sortOrder value comes from umbraco system which is used to sort the node in umbraco backend
    Mar 28, 2011 @ 13:32
    dominik
    yes but if i use your code i do not get anything back so it looks like @sortOrder is not working
    Mar 28, 2011 @ 13:57
    Pasang Tamang
    Please check your xslt once. I tried in runway module with the below xslt and works fine
          <xsl:for-each select="$currentPage/ancestor-or-self::* //umbHomepage/umbTextpage">
            <li><a href="#"><xsl:value-of select="@nodeName"/><xsl:value-of select="@sortOrder"/></a></li>
          </xsl:for-each>
          </ul>
    Mar 28, 2011 @ 14:05
    dominik
    Thanks, but i need the sort order from the Repeatable Custom Content. IN your case you are not using the Repeatable Custom Content extension I think
    Mar 28, 2011 @ 14:21
    Pasang Tamang
    I think there should be something which is responsible for ordering the repeatable contents. may be @order cuz. I can see it's using sorrting in project image.
    Mar 28, 2011 @ 14:47
    Tom Fulton
    Replied in your other thread - RCC doesn't have a sortOrder attribute but you can use position() to get the current position
    Mar 28, 2011 @ 15:38
    dominik
    now ive got another problem
    I got the following XSLT
        <ul>
            <xsl:variable name="position" select="position()" />
              <li><a href="#" onclick="ShowDiv('{$position}')"><xsl:value-of select="$position"/></a></li>
          </xsl:for-each>
          </ul>
    </xsl:template>
    So on every click i open a div with an id (position) and this works. But how can i hide all other divs instead of the one?
    I tried to use a HideDiv function but how can i tell it which divs i have to hide? for example if i write HideDiv('1') inside the onclick fucntion it works.
    Is there a way to automatically hide all divs instead of that i want to show?
    Mar 28, 2011 @ 15:57
    dominik
    ok i got it by using another variable called position-div
