  • jtmk 25 posts 20 karma points
    Feb 03, 2009 @ 18:15
    jtmk
    Canvas (aka LiveEdititor) not working in IE8
    I am trying to use Canvas to edit a RichTextEditor field on a page but I cannot get the system to enter into LiveEditing mode.
    There is a js error:
    Webpage Script Errors
    User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 1.1.4322; .NET CLR 2.0.50727; InfoPath.1; .NET CLR 3.0.04506.30; .NET CLR 3.0.04506.648; .NET CLR 3.5.21022; MS-RTC LM 8)
    Timestamp: Tue, 3 Feb 2009 17:10:29 UTC
    Message: '1.bottom' is null or not an object
    Line: 19
    Char: 15627
    Code: 0
    URI: http://137.108.32.70/Scripts/JS/sifr.js
    Does anyone know why this is happening?
    JTMK
  • Ruben Verborgh 379 posts 30 karma points
    Feb 04, 2009 @ 16:37
    Ruben Verborgh
    Welcome to Umbraco!
    What version of sIFR are you using?
    Ruben
    Feb 04, 2009 @ 19:34
    jtmk
    Thanks Ruben,
    I am not sure what version sIFR I am using, I guess whatever version comes preloaded with Umbraco 4.
    Regards
    James
  • Steve D 11 posts 41 karma points
    Aug 17, 2009 @ 14:49
    Steve D
    I had an issue with this, however when I click the Compatability View button in IE8 it resolves this issue. I'm sure the core team will have a resolution to this in the near future.
