I attempted to install the Image Resizer package, but unfortunately, it failed midway through. The following error was thrown
"Could not load file or assembly 'Dascoba.Umb.ImageResizer' or one of its dependencies.
This assembly is built by a runtime newer than the currently loaded
runtime and cannot be loaded"
Thinking it was a problem with the app pool, I changed it from .net 2.0 (classic) to different 4.0 versions. After each case, a 500 server error was thrown. After a few hours, I just deleted the Dascoba.Umb.ImageResizer.dll file, commented out a line of code in the DocumentHandlers.cs file, switched back to .net 2.0 app pool and things seems to be working again. Can someone please advise? I'd like to use the package but not sure how to stabilize.
Oh, and the line of code I commented out was 'if (property.)"
I am also unable to get this package to work. I tried to install it in a clean install of Umbraco 4.7.2. I created a Image Resizer datatype and then added that to one of my doctypes. When I go the Content section to a page that uses the doctype that has the Image Resizer datatype control on it, the page throws an error in the editor.
Dascoba.Umb.ImageResizer.ImageResizerDataType.ImageResizerDataEditorPreRender(Object sender, EventArgs e) in \\psf\Home\Documents\Visual Studio 2010\Projects\Dascoba.Umbraco\Dascoba.Umb.ImageResizer\ImageResizerDataType.cs:70
System.Web.UI.Control.OnPreRender(EventArgs e) +8948802
Is there some configuration step that I am missing?
The same story here with umbraco 4.7.2 on .Net v4.0. Also when I try to change Data Type "Property Alias" to something else it keeps changing it back to "umbracoFile".
Problem with Image Resizer package install
"Could not load file or assembly 'Dascoba.Umb.ImageResizer' or one of its dependencies. This assembly is built by a runtime newer than the currently loaded runtime and cannot be loaded"
Thank you!
Image Resizer works with .Net 4.0
I'll try to get you a .Net 3.5 version
Hi Daniel
I verified that the website was using .Net Framework 4.0 in Visual Studio so am not sure if a 3.5 version would help.
Thanks for the speedy response!
Hmm.. odd.. I built it against 4.0.. I put a 3.5 assembly on the project page just in case.
What version of Umbraco?
You can downloaded the source and try building it locally.
