  • Allan Hawkey 232 posts 303 karma points
    Mar 30, 2011 @ 11:29
    Allan Hawkey
    Blog post error
    We're using 4.5.2 with BlogForUmbraco installed - it has been working fine until yesterday.  Now, when we Save and Publish a new blog post, we get the error below, the post remains draft in the content tree, and it is not assigned to date folders.
    Plus, worse, it seems to unpublish ALL pages on the site - so the front end shows the "Looks like there's still work to do" standard Umbraco page.
    By revisiting the draft blog pst on the content tree, it is possible to Save and Publish it again, and this brings everything back to life, and publishes the post and assigns it to datefolders.  But for our clients who are posting entries in their blogs, it's a nasty error to see and takes down the whole site each time.
    Any ideas on what's gone wrong and how to fix it?
    Here's the error we're getting when we try to publish a post for the first time:
       umbraco.content.ValidateSchema(String docTypeAlias, XmlDocument xmlDoc) +51
       umbraco.content.AppendDocumentXml(Int32 id, Int32 level, Int32 parentId, XmlNode docXml, XmlDocument xmlContentCopy) +117
       umbraco.content.PublishNodeDo(Document d, XmlDocument xmlContentCopy, Boolean updateSitemapProvider) +217
       umbraco.content.UpdateDocumentCache(Document d) +395
       umbraco.content.UpdateDocumentCache(Int32 pageId) +72
       umbraco.library.UpdateDocumentCache(Int32 DocumentId) +146
       umbraco.cms.presentation.editContent.Publish(Object sender, EventArgs e) +459
       System.EventHandler.Invoke(Object sender, EventArgs e) +0
       umbraco.controls.ContentControl.savePublish(Object Sender, ImageClickEventArgs e) +96
       System.Web.UI.WebControls.ImageButton.OnClick(ImageClickEventArgs e) +108
       System.Web.UI.WebControls.ImageButton.RaisePostBackEvent(String eventArgument) +118
       System.Web.UI.WebControls.ImageButton.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument) +10
       System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +13
       System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +36
       System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1565
  • Daniel Bardi 927 posts 2562 karma points
    Mar 30, 2011 @ 12:40
    Daniel Bardi
    What changed since yesterday?
    Clear out the /App_Data/TEMP/ClientDependancy folder, touch the web.config and republish entire site from root 'Content' node to recycle cache.
    post back the result.
    Mar 30, 2011 @ 12:51
    Allan Hawkey
    Hi Daniel
    Will try this - but before I do, I know that republishing the entire site always times out - is there a way that I can extend the timeout period?
    Allan
    Mar 30, 2011 @ 13:09
    Daniel Bardi
    I think I remember seeing something in the umbracoSettings.config related to timeout...
    Mar 30, 2011 @ 13:16
    Allan Hawkey
    Can't see anything in there, unless I'm missing something obvious??
    Mar 30, 2011 @ 13:23
    Allan Hawkey
    OK - tried it anyway. Deleted the contents of the /App_Data/TEMP/ClientDependancy folder, opened and saved the web.config file and republish entire site from root 'Content' node (happened virtually immediately - normally, when I republish everything, I do it from the level below and it works through all the pages one by one, and then it times out).
    Tried publishing a new blog post - still getting the error.
    Mar 30, 2011 @ 13:26
    Daniel Bardi
    Republishing from root 'Content' node just clears cache .. that's why it was so fast.
    To tired to think right now.. I'll have to get back to this tomorrow.. hopefully you'll find a solution before then.
    Apr 06, 2011 @ 16:38
    Allan Hawkey
    Hi Daniel
    Just wondering if you have had a chance to think some more about this one?  We're still struggling with this issue, and would really appreciate your help.
    Allan
  • SinkyPars 132 posts 175 karma points
    Apr 06, 2011 @ 16:59
    SinkyPars
    Hi Allan,
    Can you post your site structure please? Is the blog under the Content node?
    S
    Apr 06, 2011 @ 17:13
    Allan Hawkey
    We have a number of blogs within this installation - we have a number of clients (all sports clubs) which share the same templates but have their own sites.  So we have:
    Content
      ClubNet
        ClubNetBlog
        Sites
          Site1
            Site1Blog
          Site2
            Site2Blog
    etc
    Does this make sense?
    Allan
    Apr 07, 2011 @ 14:47
    SinkyPars
    Have you tried deleting the indexes? Republishing the entire site(s) too?
    Cheers
    S
  • Kevin Morris 3 posts 23 karma points
    Apr 07, 2011 @ 15:02
    Kevin Morris
    Hi S,
    I'm working with Allan on this problem.  What do you mean by 'deleting the indexes' - do you mean in the database for every table?  Sorry if it's a dumb question!
    Kevin
    Apr 08, 2011 @ 10:16
    SinkyPars
    Try deleting eveything in here - App_Data\ExamineIndexes
    I think this stores some machine specific indexes which can sometimes get corrupted.
    Maybe someone from the umbraco team can confirm this?
    Cheers
    S
    Apr 08, 2011 @ 10:32
    Kevin Morris
    Thanks S,
    There's actually nothing in AppData\ExamineIndexes but there is in AppData\TEMP\ExamineIndexes.  Do you recommend deleting everything in there?
    Kevin
    Apr 08, 2011 @ 12:01
    SinkyPars
    Oops, sorry it is the AppData\TEMP\ExamineIndexe I suggest deleting everthing from.
    Cheers
    S
    Apr 08, 2011 @ 15:13
    Kevin Morris
    Thanks very much S,
    We tried that and unfortunately it didn't change anything.  We still get the same error most of the time.  It's very strange.
    I've looked at other posts which have mentioned PingServices.  Does anyone think it could be due to that.
    Also, as the error occurs at ValidateSchema it suggests that it might be an error in the database.  Is there anyway to perform an integrity check on the whole database?
    Many thanks everyone.
    Kevin
