Everytime i choose an image -> rightclick and try to add a link to a media for example an image the categories are grey and if i try to choose it I get an error.
Is there a reason why I can not put a link to a media item?
I just need it to open the image in the jquery lightbox script but it does not work
Instead of right clicking the image, try marking the image in the editor, then click the "Insert/edit link"-button in the top. Now you should be able to select a media item to be linked to. Does this help you?
ok got it working by just selecting an "disabled" image. Is there a reason for disabling the images (show grey)?
Now i need a possibility to select a class for the link inside the link property box. So it would be great if I can add a dropdown under the "title" property with a class called "lightbox"
Tinymce add link to media problem
hello,
Hi dominik
/Kim A
No i cant get the image marked - why can i not use the media section if i click on the image and choose add link?
I cant understand sorry
PS: i just tryed marking - same problem here
How can i get this?
Is there any possibility of adding a "link class" property to the content / media picker?
This would be great
