I just installed Courier 2.0 and get an error "
Now i can not reach the backend any more. How can I uninstall this package manually so i can login to backend?
Not sure how to fully remove it from the database and everything, but you should at least be able to remove the DLL from /bin/ and that should hopefully get you back into the backend.
ok it would be great if someone of the core developers would give an answer in the courier forum.
PS: removing the dll does not solve this problem
Uninstall package manually
This assembly has been built with an evaluation version of SmartAssembly, which has expired."
