  • lpastor 140 posts 19 karma points
    Feb 12, 2009 @ 15:29
    lpastor
    Roles and priviledge
    I have a problem
    I tried to have a look at the permission side. The problem is that you cannot copy a user.
    There is also now way to give a group permissions in the backend.
    It is done on the user level by ticking some parts.
    It directly means that you cannot create a group of users (editors for example) that have the same permissions in the backend.
    If you have for example 10 editors, you have to create them all by hand and manually tick the boxes...
    Is there a way to also be able to give a Member Group a permission instead of users.
    In this way you can create a Member Groups and make users part of that group.
    If you then set the permissions for this group, they apply to all members in that group...
    If I could have the permissions set to a group, it would solve the problem...
    can sombody point me in good direction or help me with this ???
    thanks
    Feb 19, 2009 @ 23:52
    lpastor
    I just to ask is in v3 in umbraco privilege of user is group based or I have to set for each user?
    Feb 23, 2009 @ 09:33
    lpastor
    Anyone?
