  • Bas Wensveen 54 posts 75 karma points
    Apr 01, 2011 @ 14:56
    Bas Wensveen
    Umbraco administrator empty treenavigation
    I have read several posts on this issue, but did not find the solution for me.
    As the summay suggests, after login onto Umbraco I get the umbraco UI. Everything looks fine except all nodes (Content, Media, Developers etc) in the Content navigation tree are empty.
    Changing the read/write premissions on the server of the hosting provider is not a option.
    umbraco v 4.0.3 (Assembly version: 1.0.3680.15881)
    AJAX toolkit version 1.0.10920.32880
    Apr 01, 2011 @ 15:04
    Tom Fulton
    Is this a brand new install?  Or an existing one that went haywire?
    I have seen this happen on existing installs after adding a new CustomAction or other tree "extensions".  Did you change anything recently?
    Either way, Umbraco will require write permissions if you don't have them set already...
    -Tom
    Apr 01, 2011 @ 15:22
    Bas Wensveen
    It is a copy of an existing website I developed a year ago. I did not develop any CustonActions or tree "extensions".
    I have set the write premission on the following folders:
    bin
    config
    css
    data
    masterpages
    media
    python
    scripts
    umbraco
    usercontrols
    web.config
    xslt
    Apr 01, 2011 @ 16:21
    Bas Wensveen
    Is there way to debug or trace events to investigate this issue?
    Apr 01, 2011 @ 16:32
    Tom Fulton
    You might start by checking the umbracoLog table to see if any errors are logged.  If not, you might try using a HTTP sniffer like Fiddler and see if any errors (500) are returned and see if you can see the raw error text.  I would assume it's probably a permissions issue though.
    -Tom
  • Michael Latouche 504 posts 819 karma points MVP 4x c-trib
    Apr 01, 2011 @ 16:36
    Michael Latouche
    Hi Bas,
    Did/Can you also set the permissions on your temp folder? See this post for more information: http://our.umbraco.org/forum/using/ui-questions/6461-No-nodes-ind-the-backend.
    Michael.
    Apr 01, 2011 @ 17:25
    Bas Wensveen
    My provider doesn't allow me te change the permissions on the temp folder. On my server the website works fine, but on the hosting server it doesn't. I have multiple site there work fine.
