  • Connie DeCinko 931 posts 1160 karma points
    Apr 01, 2011 @ 18:56
    Connie DeCinko
    Query/Report of empty fields
    I need to create a list of pages where my SEO fields are empty.  How do I query the xml to find this?
    Apr 02, 2011 @ 10:21
    Kim Andersen
    3
    You want to run through all of your nodes and then list the ones that doesn't have a value in the SEO field?
    If that's the case try something like this:
    <xsl:variable name="root" select="$currentPage/ancestor-or-self::root" />
    <xsl:for-each select="$root//*[@isDoc and SEO='']">
    <!-- All of the nodes that has an empty SEO field will be run through in this for-each -->
    </xsl:for-each>
    The above for-each will only run through the nodes that has an empty SEO field.
    /Kim Andersen
    Apr 04, 2011 @ 19:42
    Connie DeCinko
    Thanks Kim.  That gave me enough to be dangerous.  I created at least a temporary page that our authors can use to do some housekeeping.  Later, I need to make it secure since no one but authors need see that list.  It would be nice if I could run this in the back end and link right to the content node for editing.
    Apr 04, 2011 @ 20:28
    Kim Andersen
    Hi Connie, you're very welcome!
    I think you need to make a user control for that if you want it to be a part of the backend as you describe. But it should for sure be possible.
    /Kim Andersen
    Apr 05, 2011 @ 17:08
    Connie DeCinko
    Yeah, making this report into a Dashboard report would be the perfect solution.
    Just need to figure out how to do that with XSLT.
