  • anthony hall 222 posts 536 karma points
    Feb 15, 2009 @ 19:58
    anthony hall
    How to add current node to marco
    I thought i posted this quesiton? Anyway here goes again.
    Wondering how to add the current node into the following macro. ie imageID
    I can PageField 'MyImage' that returns my current node. So really this just a syntax question.
    I basically want to do something like
    any thoughts?
  • Scott Hugh Alexandar Petersen 349 posts 164 karma points
    Feb 15, 2009 @ 21:32
    What about doing a
    in your XSLT file?
    Feb 16, 2009 @ 08:26
    Dirk De Grave
    Hi Anthony,
    If you need to send in a property MyImage into the macro, you could use:
    [code][/code]
    And what is that macro supposed to do? Get the image url for the image node? In that case you no longer need to use a macro, you could use some inline xslt to get the image
    Have a look at this url http://umbraco.org/documentation/books/inline-xslt for a brief expl on using inline xslt.
    Regards,
    /Dirk
    Mar 04, 2009 @ 12:33
    anthony hall
    thanks Dirk, very useful link.
    .wrapper-portfolio
    background-image: url('');
