  • lpastor 140 posts 19 karma points
    Feb 16, 2009 @ 22:36
    lpastor
    How to use a tranlator role in Umbraco ?
    maybe dummy question but I see there is role called translator , but I cannot found the way to use it ?
    Is there some example or some document about it ... I starting a new site and client ask me to create multilingual web site with translator role ..
    Any suggestion where to start will be great
    Thnks
    Feb 16, 2009 @ 22:43
    Dirk De Grave
    Hi lpastor,
    In short:
    - Create a translator user
    - Create another user (writer will do I think)
    - Create new content
    - Right-click new content and select 'Send to translate'
    - Choose a translator from the dropdown
    - Choose language to translate to
    - Optionally choose if child node pages should be translated as well.
    - Make sure smtp settings are configured in web.config
    Translator user should get a mail with instructions on how to translate the document.
    Regards,
    /Dirk
    Feb 16, 2009 @ 23:22
    lpastor
    Dirk
    again you are first [-o<
    OK I understand now, but I still don't understand why I need writer ? and what is different between writer and editor ?
    and why in umbraco 4 when I create one of this users type I can not access to back end ...!!
    I always get
    "Index was outside the bounds of the array.
    Exception Details: System.IndexOutOfRangeException: Index was outside the bounds of the array.
    Source Error:
    Stack Trace:
    [IndexOutOfRangeException: Index was outside the bounds of the array.]
    umbraco.cms.presentation.umbraco.PageLoad(Object sender, EventArgs e) +1672
    System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14
    System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35
    System.Web.UI.Control.OnLoad(EventArgs e) +99
    umbraco.BasePages.BasePage.OnLoad(EventArgs e) +15
    System.Web.UI.Control.LoadRecursive() +50
    System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
    thnks
    Feb 17, 2009 @ 08:16
    Dirk De Grave
    Answer to 'System.IndexOutOfRangeException' to be found at
    http://forum.umbraco.org/yafpostst8254Can-not-log-in-in-back-like-translator-.aspx?find=unread
    Regards,
    /Dirk
