Is it possible to get an overview of an entire site in umbraco?
I'm looking for a possibilty to export all pages to PDF or similar. This is for a person that has to get the site reviewed and approved by a superior officer before publishing it.
Thanks for a very fast response. I think your suggestion would do fine for minor changes.
I was thinking more of a major redo of a website in umbraco. Given an old outdated website, having a person check and change alot of stuff and then finally have someone aprove the whole thing.
How to get an overview of a site
Best regards
JF
Hi Jens,
You could take a look at the built-in notifications system? http://our.umbraco.org/wiki/reference/umbraco-client/context-menus/notifications
This will email/notify an admin/editor user for content changes that need to be approved/published.
Cheers, Lee.
Hi Lee
Best regards
JF
Hi Jens,
If you are after outputting a PDF, take a look at the XSLT PDF Creator package.
Then depending on how you want to present the website's content, you could write some XSLT accordingly?
Simple example:
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " "> ]> <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:msxml="urn:schemas-microsoft-com:xslt" xmlns:umbraco.library="urn:umbraco.library" exclude-result-prefixes="msxml umbraco.library"> <xsl:output method="xml" /> <xsl:param name="currentPage"/> <xsl:template match="/"> <!-- navigate to the root node --> <xsl:apply-templates select="$currentPage/ancestor::root/*[@isDoc]" /> </xsl:template> <xsl:template match="*[@isDoc]"> <div> <!-- output all the attributes and properties --> <xsl:apply-templates select="@* | *[not(@isDoc)]" /> </div> <!-- output all the child documents --> <xsl:apply-templates select="*[@isDoc]" /> </xsl:template> <xsl:template match="@* | *[not(@isDoc)]"> <dl> <dt> <xsl:value-of select="name()"/> </dt> <dd> <xsl:value-of select="." disable-output-escaping="yes" /> </dd> </dl> </xsl:template> </xsl:stylesheet>Feel free to use this as a basis... obviously, you'd need to add all the XSL-FO markup for the PDF formatting! ;-)
Cheers, Lee.
