  • dominik 711 posts 733 karma points
    Apr 04, 2011 @ 16:30
    dominik
    TinyMCE paragraph problem on Macros
    I wrote some macro which adds a link to a usercontrol. If I add this via the TinyMCE it works but after saving it a second time there is everytime put a <p> arround which i do not need. I want the link to appear on the same position it was added.
    How can i remove the Paragraph which is put above the macro after saving it the first time?
    Apr 04, 2011 @ 19:00
    Hi Dominik
    It's a well known annoying behaviour. I'm not sure why it happens and that the possible fix could be. But if you, after you hit save, click the "HTML" button you can manually remove it by deleting the emtpy <p></p> element from the source and hit "update". Remember to save and publish.
    Apr 04, 2011 @ 20:45
    Apr 05, 2011 @ 08:08
    dominik
    I just tryed the package but it does not solve this problem. Also removing the <p> manually is not a solution i can use.
    I think the problem is that umbraco puts a div arround the macro which is not allowed inside a paragraph. Is it possible to remove the div?
    It would be great if I can fix this "issue" so i can paste a link which a macro generates inside a text without a linebreak.
  • Morten Balle 38 posts 129 karma points
    Oct 28, 2013 @ 09:22
    Morten Balle
    Hi dominik
    Di you ever solve this..?
    Best,
    Moriten
