    Apr 05, 2011 @ 15:38
    Ismail Mayat
    RTE macro issue
    I am using umbraco 452 i have rich text edit field and I am inserting macro into the content. It all works except for one thing if i insert the macro in between line of text eg:
    some text {macro here} line continues here.
    When the page renders i get
    some text
    macro output
    line continues here
    In the html before the macro an end p tag is inserted and after macro a start p tag is inserted. If you remove using the html editor and update it still re appears. Is there a way to stop this?
    Regards
    Ismail
  • Nik Wahlberg 639 posts 1237 karma points MVP
    Apr 05, 2011 @ 15:39
    Nik Wahlberg
    I would love to see a solution to this one. I've had the same issue on a number of installation.
    Cheers for any ideas.
  • Matt Brailsford 4125 posts 22224 karma points MVP 9x c-trib
    Apr 05, 2011 @ 15:40
    Matt Brailsford
    I don't think you can stop it (I could be wrong), but I think that is one of the reasons Lee started the shortcodes project (http://our.umbraco.org/projects/developer-tools/shortcodes) so you can render content, easily, inline.
    Maybe you could give that a go?
    Matt
    Apr 05, 2011 @ 15:41
    Matt Brailsford
    Ooops, just realized, it says it's for 4.7 only, so probably not going to help you, sorry.
  • Christian Palm 278 posts 273 karma points
    Apr 05, 2011 @ 15:44
    Christian Palm
    We have not found a solution. When we are designing/prototyping macroes that should be used in the editor we are always designing the macro as a block element (Full width) like a div (not floating).
    You can how ever have two properties on your macro: Text before and Text after and then output the text from inside you macro
    Apr 05, 2011 @ 15:49
    Ismail Mayat
    Christian,
    Think that is going to be best way for now.  I wonder though if there is something in the tinymce config files that actually causes this to happen?
    Regards
    Ismail
    Apr 05, 2011 @ 16:12
    Ismail Mayat
    k update on this just installed shortcodes on 452 and it works so just gonna knock up a base extension and we should be on a roller or as lee put it http://www.youtube.com/watch?v=Qr4PcOQYFAw
    Apr 05, 2011 @ 16:14
    Matt Brailsford
    Sweet! Glad it worked for you.
    Matt
    Apr 05, 2011 @ 16:22
    Nik Wahlberg
    Nice alternative, I'll have to check that out too. Thanks for the tip Matt!
