(version 4.0.4.2)
Hi guys, i have just launch my new page, but i have a little problem with hostnames.
I have 4 domains .es/.eu/.ma/.mx and each one would go to each language. my site tree is:
root
-------home ES (spanish)
-------home FR (french)
-------home EN (english)
-------home PT (portuguese)
Each one have 1 hostname assigned to automatically change language. But this dont work. What must i modify on IIS to get it working?
When i go to "domain.ma" (french), dont work.
i have a language selector using "domain.es" , it don't work for dictionary items. But if i enter with IP language changer works perfect.
Where is the problem?
Thanks guys,
Which version of IIS are you using?
If it's 7.x then select your website in IIS then clikc "bindings" on the right hand side, then "Add" here you must add all the domain names you want to point to the site.
Rich
Thanks Rich, was this but also my problems was domain redirection with ISP. I was doing redirections with frames.
Upload image
Multidomain, IIS and language. Hostnames dont working
(version 4.0.4.2)
root
Thanks guys,
Rich
