I have been searching for this for i while but haven;t been able to come up with a proper solution. I want to extend the tinymce wysiwyg editor with font selection (Airal, Verdana et cetera). Where can i change what setting to achieve this?
I'm using Umbraco 3.0.3 with "umbraco" theme on tinymce.
I hope someone can give me some direction.
TinyMCE - Add Font selection and style
Hi all,
Regards.
It's - thankfully - not possible in Umbraco. You should use CSS classes/elements instead which will give you a more semantic markup.
Leave font selection and sizes to birthday invitations to Word ;-)
Ok, thanks for that. In case of pre determined style classes (css). Is it then possible to select a style from a listbox in the editor?
