  • Alexander Huyghebaert 6 posts 26 karma points
    Apr 08, 2011 @ 08:49
    Home page is a blank page
    Our site has worked for a couple of years now, but now suddenly when we go to www.domain.com the site is blank
    If i go to www.domain.com/homepage.aspx everything works fine.
    When i do www.domain.com/?umbdebugshowtrace=true there's following error:
    No template defined (value=0)
    Anyone knows a solution?
    I need kinda fast a solution.
    Apr 08, 2011 @ 08:58
    I've checked in the backoffice, and there is a template defined for homepage
    Homepage is also the first Node after Content, so this should work i guess?
    Kim Andersen
    Hi Alexander
    Did you do anything in the code, the server or inside of Umbraco? Or it just suddently stopped working?
    Could you maybe try to right-click the Content-node and click the "Republish entire page" to see if this helps.
    /Kim A
    Apr 08, 2011 @ 08:59
    Hi Kim,
    It suddenly stopped working.
    The Republish entire page, won't harm the site, I mean (i don't need to publish every page afterwards?)
  • Pasang Tamang 258 posts 458 karma points
    Apr 08, 2011 @ 09:08
    Pasang Tamang
    Did you check the hostname in umbraco backoffice? You can check it by right clicking on top node and manage hostname
    Pnima
    Apr 08, 2011 @ 09:10
    Hello Pnima,
    There are no hostnames set.
    When i set those, it works, but then i can't change the language anymore and no other page except the homepage works.
    Apr 08, 2011 @ 09:13
    Pasang Tamang
    Which lanugage you prefer? If you need additional language then you can add from settings >> languages and Plz try republishing the other pages also.
    Pnima
    Apr 08, 2011 @ 09:18
    There are already 6 languages set.
    Everything worked untill tuesday, without a change.
    Alexander
    Apr 08, 2011 @ 10:09
    Hello Kim,
    Republishing solved the problem.
    Looks like there was a problem in the config files or somehow.
    Thanks!
    Apr 08, 2011 @ 10:41
    Kim Andersen
    Cool, sounds great Alexander. Often when these weird situations accour, it's a good idea to republish the content = Updating the umbraco.config file :)
    /Kim A
