I have installed Umbraco 3.0.6 from Codeplex - including the umbraco.webservices.dll hotfix. Everythins seems working as intended except that the content disappears after some time. When I re-publish the content everything is fine. For about 5 minuttes. Then the content disappears again.
What can be wrong? Tried to search the forum but did not find something useful.
My templates are rendered correctly - only the dynamic content disappears.
I tried to turn off xml-caching but that really screwed up! Also checked permissions but did not find anything suspicious. During install the install guide stated that permissions were fine so unless that is not sufficient I do not think the problem was related to security.
Anyway.. I ended up doing a re-install and that fixed it. My first install was an empty website and the second time I chose the Website wizard template. Maybe something messed up in the first place.
Apparently I was too fast to saying this was fixed.
I turns out that the content is unpublished after some time. When I go to the site I get redirected to /config/splashes/noNodes.aspx. When I publish the content tree the content is visible again for some time. It seems to me that content is published only through out my session.
What can be wrong here? During install the guide stated that permissions were perfect.
Check if the users NETWORK SERVICE and ASPNET both have full control over the folders:
data, media, css, masterpages, xslt, scripts, python and the web.config file.
Note: the user NETWORK SERVICE usually is the one, that is the user that runs the application-pool. It can have been altered though, you might want to check the application-pool to check which user it runs under.
Yes, that has changed since then. I'm not sure what problem you might run into, but if you perform a search here on the forum for medium trust, you'll find quite a number of posts.
Content disappears??
Best regars,
Anders
This behaviour is all about permissions.
Check your permissions and triple-check them again.
HTH,
PeterD
I also have experienced some weird behavior due to xml-caching turned on in the umbracoSettings.config. It wouldn't hurt trying to turn it off.
Thank for the suggestions.
Regards,
Anders
That can be misleading.
HTH,
PeterD
I am running umbraco in a hosted environment so I have no control over apppools.
Are there any special requirements?
Have your provider check which user is used for the apppool.
That user AND the ASPNET user both need full control over mentioned folders.
If you can change permissions on folders yourself, you could try to use NETWORK SERVICE first before contacting the hosting provider.
HTH,
PeterD
Thanks Peter.
I have requested info on setting folder permissions from my hosting provider.
My hosting supports Medium Trust. I guess this is sufficient for Umbraco 3?
Hm, Umbraco needs full trust actually. You might run into more problems if the site is set up in medium trust....
So this has changed since version 2 I guess. I have an old site running on version 2.
So how are people getting around this? I guess there are not many hosting providers that offer Full Trust?
Wow - can not believe this! I guess the 80/20 rule does not apply here...
As I see it is caused by .Net reflection and Xslt extensions.
Unfortunately this makes Umbraco 3 (and 4) useless for me :-(
[quote=amunk]Wow - can not believe this! I guess the 80/20 rule does not apply here...
Unfortunately this makes Umbraco 3 (and 4) useless for me :-([/quote]
Change hosting provider! There are good and not very expensive ones that offer full trust.
