  • Biagio Paruolo 1621 posts 1914 karma points c-trib
    Apr 08, 2011 @ 14:41
    Biagio Paruolo
    Error RichText Editor: /umbraco/plugins/tinymce3/insertImage.aspx not exist!
    Errore server nell'applicazione '/'.
    Impossibile trovare la risorsa.
    Descrizione: HTTP 404. La risorsa che si sta cercando (o una delle sue dipendenze) potrebbe essere stata rimossa, rinominata o non essere temporaneamente disponibile. Verificare che l'URL riportato di seguito sia stato digitato correttamente.
    URL richiesto: /umbraco/plugins/tinymce3/insertImage.aspx
    Informazioni di versione: Versione di Microsoft .NET Framework:4.0.30319; Versione di ASP.NET:4.0.30319.1
    Apr 08, 2011 @ 20:18
    Hi Biagio
    I'm afraid not many on the forum undrstand italian...could you perhaps translate the ghist of this error message?
    And what version of Umbraco does this happen on? And is it a clean install or an upgrade?
  • Daniel Bardi 927 posts 2562 karma points
    Apr 08, 2011 @ 23:28
    Daniel Bardi
    I Tranoogled the text:
    Server Error in '/'.
    Can not find the resource.
    Description: HTTP 404. The resource you are looking for (or one of its dependencies)could have been removed, renamed or is temporarily unavailable. Verify that thefollowing URL is spelled correctly.
    Requested URL: / umbraco/plugins/tinymce3/insertImage.aspx
    Version Information: Microsoft. NET Framework: 4.0.30319; ASP.NET Version:4.0.30319.1
    Apr 08, 2011 @ 23:30
    Daniel Bardi
    Looks like a missing file in the installation... Did you just recently install umbraco and/or upgrade?
    I'd recommend copying the clean /umbraco structure (after backup of course) and try again.
    Also check rights on the folder.
    Apr 09, 2011 @ 14:34
    Biagio Paruolo
    I think that is an Umbraco install bug. That file is not present into that folder. I've made a fresh install.
    Apr 09, 2011 @ 19:25
    Daniel Bardi
    Sounds right... let us know the result.
