I have this weird problem. For a package (Language Selector) to work properly, I need to add the runat=server attribute in the head-tag
But when I do that, the spaces and hyphen between the dynamic values are gone. This markup:
<title><umbraco:Item field="siteName" recursive="true" runat="server" /> - <umbraco:Item field="pageTitle" runat="server" recursive="true" /></title>
renders like this:
siteNamepageTitle (e.g FlexisleHomepage)
while it should be siteName - pageTitle (e.g Flexisle - Homepage)
If I remove the runat=server attribute from the head-tag the <title> tag renders normally: siteName - pageName
Does anyone has a clue what's going on?
Thanks for your help,
Anthony
Create a HeadTitle macro... it will also clean up your template.
You could also do this:
<title><umbraco:Item field="siteName" insertTextAfter=" - " recursive="true" runat="server" /><umbraco:Item field="pageTitle" runat="server" recursive="true" /></title>
Hi Daniel,
Thanks a lot, I inserted the insertTextAfter=" - " attribute and this solved the problem:
www.flexisle.com
greetings,
Umbraco is a beautiful (and flexable) thing... love it..
Glad I could help.
no spaces in title tag
renders like this:
Anthony
<title><umbraco:Item field="siteName" insertTextAfter=" - " recursive="true" runat="server" /><umbraco:Item field="pageTitle" runat="server" recursive="true" /></title>Hi Daniel,
www.flexisle.com
greetings,
Anthony
Glad I could help.
