  • Nalin 1 post 20 karma points
    Feb 27, 2009 @ 20:33
    Nalin
    Using page content from Umbraco site in other ASP.NET site
    I have Umbraco 4.0 installed and running properly as a CMS.
    The pages that are created in the CMS need to be presented in a different ASP.NET site.
    What is the best way to go about this? (other than migrate the other ASP.NET site to Umbraco).
    The simplest solution seems to be to use an Iframe. Is that the best way?
    Thanks!
    - Nalin J
  • Petr Snobelt 923 posts 1535 karma points
    Feb 28, 2009 @ 09:08
    Petr Snobelt
    1. On asp.net page you can create http webrequest to umbraco site (you should cache results)
    2. umbraco data file - xml ad extract information from it
    3. Iframe (maybe with alternative template) or maybe use alternative template only on different asp.net site
      Petr
    Feb 28, 2009 @ 09:22
    Dirk De Grave
    Petr's first option looks ok if you need to get the exact same page that should have been served by the umbraco cms.
    Another solution would be to query the umbraco db for specific data using the umbraco api (or even through webservices - I wouldn't go directly into the umbraco data file
    Just my 2 cents
    Regards,
    /Dirk
