  • Kanika 3 posts 20 karma points
    Mar 03, 2009 @ 05:15
    Kanika
    How to accept inputs from users ?
    For example , I have a form and the inputs have to be filled by the user.? how do we do this in Umbraco ?
    Can some one give me some pointers where i can get the information and the steps to do it..???
    Mar 03, 2009 @ 08:25
    Dirk De Grave
    Depends what you need to do with the user input. What type of info is it? Do you want to save this as a node in umbraco? If so, use the Document.MakeNew() function. Full details on the function can be found at http://umbraco.org/apiDocs/ (Don't forget the trailing slash, or you'll get a 404)
    Here's a code snippet to help you on the way:
    [code]DocumentType type = DocumentType.GetByAlias("DocumentTypeAlias");
    User user = User.GetUser(0);
    int parentNodeId = -1;
    Document newDocument = Document.MakeNew("Text", type, user, parentNodeId);
    if (newDocument != null && newDocument.Id > 0) {
    newDocument.getProperty("PropertyAlias1").Value = "Property1Value"; newDocument.Publish(user);
    umbraco.library.UpdateDocumentCache(newDocument.Id);
    }[/code]
    Hope this helps.
    Regards,
    /Dirk
  • Daniel Lindstrom 454 posts 271 karma points
    Mar 03, 2009 @ 11:14
    Daniel Lindstrom
    You can also have a look at Doc2Form and see if that works for your needs.
