render image from media using media picker in Umbraco 4.5.2
hi,
This is probably a simple thing but it giving me a headache i think i need a rest
basically am using 4.5.2 and have inserted a number of image within the media section all i need to know is how to render them in a template i keep geting the id in my img src.
hi,
simples but busting my...
king regards
Neil.
you can't render them to a template without a macro
here's an example for xslt
<xsl:variable name="media" select="umbraco.library:GetMedia($currentPage/imageProperty, 0)" /> img src="{$media/umbracoFile}" width="80" height="80" />Razor example
@{dynamic image = new umbraco.MacroEngines.DynamicMedia(@Model.imageProperty);
img src="@image.umbracoFile" width="80" height="80 />
add a "<" on the img string, the forum try to render them as img :)
Hi both of you
Actually, yes you can render the image in your templates. You can do like this:
/Kim A
