Very odd one this one, really hoping someone here can help:
We have an Umbraco installation which is running 4.6.1, upgraded from 4.0.1 about 3 months ago. Everything seems to be working correctly, we can create, edit and remove content, templates, doctypes and so on.
However, all content in the system, pre-existing and new content pages do not have forward slashes in the Alternative links under the properties tab.
In this case, SubPage3 would have a correct "Link to document" of "/homepage/subpage2/subpage3.aspx", however, the Alternative links would look like this:
And so on. Has anybody seen anything like this before? How are these links created, and is it possible to change them? I am reluctant to republish the entire site as it is rather large, and as new pages are being created with the same problem, I suspect that not much will change.
Anyway, any and all feedback, theories would be welcome!
Could you perhaps try to refresh the xml cache? (It's done by right clicking the "Content" node, when you right click choose the "republish entire site").
Does this help?
It seems very odd and I have never seen this before. Maybe you should also check to see if something has been modified in the appSettings part of the web.config or perhaps in umbracoSettings.config.
Thanks for your reply, unfortunately refreshing the XML cache has no effect. I can't see anything which is obviously different in the web.config or the umbracoSettings.config from our other 4.6.1 installations.
Does anyone know how the system generates these links? They do not appear to come from the XML as I've looked at that file and I can't see anything which matches, so are these stored in the database somewhere?
Alternative Links
Hi All,
Example:
Tree:
Website
--HomePage
----SubPage1
----SubPage2
------SubPage3
http://subDomain1.mywebsite.comhomepagesubpage2subpage3.aspx
http://subDomain2.mywebsite.comhomepagesubpage2subpage3.aspx
Rob
Hi Rob
Does this help?
Hope this helps.
Hi Jan,
Rob
Hi Rob
That's very weird. What happens if you choose to only publish a few of the nodes? Does the dot notation still persist then?
