  • gzezetko 8 posts 20 karma points
    Mar 05, 2009 @ 16:49
    gzezetko
    problem of creating the numeric name page.
    In umbraco v 4.0.0 I have a problem of creating the numeric name page. I did not have this problem in the previous versions of Umbraco.
    For example after I create a page with the name: 2009 and try to start from Content->Properties-> Link to document /2009.aspx I am getting
    an error:
    Page not found
    No umbraco document matches the url 'http://localhost/2009.aspx'
    umbraco tried this to match it using this xpath query'2009')
    This page can be replaced with a custom 404 page by adding the id of the umbraco document to show as 404 page in the /config/umbracoSettings.config file. Just add the id to the '/settings/content/errors/error404' element.
    Is there is any settings in webconfig files which should be changed? Or Umbraco v.4 does not let to create the pages with numeric names?
    (It is not a good practice)
    It would be nice to get the answer on this one.
    Thank you
  • greggd@tempworks.com 7 posts 23 karma points
    Mar 09, 2009 @ 03:27
    i am having the same 'link to document' problem. appears to happen because a document got moved.
  • Oskars Podans 4 posts 20 karma points
    Mar 12, 2009 @ 14:18
    Oskars Podans
    After moving document "Link To Document" is not updated. You have to republish document! Same happens when you change hostnames.
