umbracoRedirect - will referring page show in analytics?
I've set up a redirect to allow a short URL to be used in advertising materials - e.g. domainname.com/advert
I used the built-in umbracoRedirect property. What I need to know is whether the referring page will show up in the google analytics report, or whether umbraco does this 'behind the scenes'.
If not, is there a simple way I can measure what percentage of hits to a certain page came from this new, short url vs. the main, longer url?
So I guess your question actually relates to whether a 302 redirect passes the referal in google analytics, something I couldn't find a definitive answer for.
As far as I can tell, a 302 doesn't look like it'll show the referrer as my page with umbracoRedirect on it. That link tagging seems like it'll do the trick, I just need to figure out how to add that as a redirect vs. using umbracoRedirect. Actually, I wonder if we can just do that on the server but redirect it to the tagged url...
Hey,
umbracoRedirect makes a 302 redirect http://our.umbraco.org/wiki/reference/umbraco-best-practices/umbracoredirect
You could add some code to do a redirect and tag the url with an analytics tag http://www.google.co.uk/support/googleanalytics/bin/answer.py?answer=55518
Rich
Thanks Rich,
Really appreciate the help, thanks again.
If it's for one unique page you can set up a url rewrite
Something like (not tested and don't know the effects of a permanent redirect)
<add name="CampaignRedirect" redirectMode="Permanent" redirect="Domain" ignoreCase="true" rewriteUrlParameter="IncludeQueryStringForRewrite" virtualUrl="http://domainname.com/advert" destinationUrl="http://domainname.com/advert.actualpage.aspx?querytrackinghere" />Rich
Or this
http://our.umbraco.org/wiki/how-tos/telling-a-page-to-redirect-to-an-external-url
Rich
