  • James N 3 posts 23 karma points
    Apr 14, 2011 @ 18:06
    James N
    Dynamic file paths for images
    Ok, there has to be an easy answer to this that I am missing....
    I have a local install of Umbraco with a http://localhost/umbraco1 for development purposes.
    First, any images inserted within an article have an absolute address which breaks. For example: <img src="/media/99/picture.jpg"> really needs to be <img src="/umbraco1/media/99/picture.jpg">.  The RichText editor forces images back to the default absolute address. Is there a fix?
    Second, macros that load images need paths that adjust to your position in the site map.
    What I am looking for is something like this within the XSLT file
    <img src="{umbraco.library:SuperDuperNiceUrl('media/misc/picture.jpg')}">
    which will adjust the image path to:
    <img src="/umbraco1/media/misc/picture.jpg">
    Suggestions anyone?
    Apr 14, 2011 @ 18:15
    Tom Fulton
    Is /umbraco1 a virtual directory with it's own application or just a regular subfolder?  I believe the above issue will happen when it's a regular subdirectory and not an application.
    Also are you running 4.7?  There was a bug in previous versions (< 4.6 ?) with the same issue when running in a virtual directory.
    -Tom
    Apr 14, 2011 @ 18:25
    James N
    It is a virtual directory with its own application.
    no, I just realize it is not version 4.7.  So, obviously I need to upgrade before continuing.
    -Jim
    Apr 14, 2011 @ 20:08
    James N
    Ok, this is upgraded. It is running at 98%. I might just do a fresh install of 4.7.0 on a host where it can reside in the site root. There are some new quirky issues arising requiring hacking. It just doesn't play nice within a virtual directory.  Thanks
