  • dominik 711 posts 733 karma points
    Apr 15, 2011 @ 09:52
    dominik
    Dictonary Stack Trace error
    I just looked into my stacktrace and get the following error:
    library    Error returning dictionary item 'GuestAccount'
    No key GuestAccount exists in dictionary
      at umbraco.cms.businesslogic.Dictionary.DictionaryItem..ctor(String key)
      at umbraco.library.GetDictionaryItem(String Key)    0.00219086630276236    0.000102
    item    Start parsing '#GuestAccount'    0.00236116449376701    0.000170
    item    Done parsing '#GuestAccount'
    So i do not know what this error is saying
    First there is no item and after this error the parsing works?
    There is an dictonary Item called "GuestAccount"
  • Richard Soeteman 4054 posts 12927 karma points MVP 3x
    Apr 15, 2011 @ 12:19
    Richard Soeteman
    Dictionary items are Case sensitive. Also make sure you don't have a double entry in your databasde which can lead to some weird errors sometimes.
    Must be something that is causing the error.
    Richard
    Apr 15, 2011 @ 12:38
    dominik
    No there is no double entry of this item.
    The only thing it is a child element of another item. Can this be se reason for this error?
    Apr 15, 2011 @ 14:03
    Richard Soeteman
    No should work fine, how do you retrieve the Dictionary item?
