  • Evan 344 posts 99 karma points
    Mar 13, 2009 @ 14:28
    Evan
    having a very strange problem with an upgrade
    I am upgrading from v4 beta 1 to the current release of v4. When I change the configuration string to the current database on a test server, the icons for content, settings, developer, media, etc. are all broken. When I change the string to another database that is using the current v4, the icons are back. What could be the problem with the site using v4 beta 1 that is causing this to happen?
    Mar 16, 2009 @ 16:31
    Evan
    Anyone?
  • Peter Dijksterhuis 1442 posts 1722 karma points
    Mar 16, 2009 @ 16:40
    Peter Dijksterhuis
    There has been a few updates in the DB that causes this behaviour. There is no upgrade-script from beta to final version so you'd have to make the changes manual in the DB.
    There should be a post somewhere describing what you should do.
