  • dominik 711 posts 733 karma points
    Apr 19, 2011 @ 10:31
    dominik
    Sort Media Items does not work
    I am using umbraco (version 4.7) and try to add some images via the media content section.
    If i try to sort them with the umbraco backend sort function the images are not shown in the correct way in the frontend. Is there an error on sorting images via media type?
  • Jeroen Breuer 4909 posts 12266 karma points MVP 6x admin c-trib
    Apr 19, 2011 @ 10:37
    Jeroen Breuer
    Perhaps it's related to this bug, but it should be fixed: http://our.umbraco.org/forum/core/41-feedback/12159-Refresh-media-cache-after-sorting
    Jeroen
  • Pasang Tamang 258 posts 458 karma points
    Apr 19, 2011 @ 10:45
    Pasang Tamang
    I'm also facing same problem. Using umbraco 4.7 version, if a create some media then sort starts from 1 and if I sort them then sort starts from 0. Seems it's still bug in this version also.
    Pnima
    Apr 19, 2011 @ 11:30
    dominik
    i think i got some more information
    So lets describe my scenario.
    Ive got some media types and an xslt which has an xsl:for-each loop for each type. Now i want to sort all of them with the sortOrder.
    It works only for one for-each loop but not for all. So i can use it for one media type.
    What i need is to get it working for all media types. So i can sort through different media types.
    Anybody an idea?
