  • dominik 711 posts 733 karma points
    Apr 19, 2011 @ 14:14
    dominik
    After Umbraco Upgrade - Wrong Macro Parsing
    Yesterday i updated umbraco from version 4.5.2 to 4.7
    Until now every macro I insert via the content richtext editor is rendered like this:
    <?UMBRACO_MACRO macroAlias="Accordion" />
    How can i remove this that it is working like it has do on umbraco 4.5.2?
    Apr 19, 2011 @ 14:35
    dominik
    so what i have done is changing:
    <xsl:value-of select="$currentPage/contentTab1Text" disable-output-escaping="yes" />
    to:
     <xsl:value-of select="umbraco.library:RenderMacroContent($currentPage/contentTab1Text, $currentPage/@id)" disable-output-escaping="yes" />
    But how can i get now the macro working which is inside the contentTab1Text
