  • Swapnil Singha 3 posts 23 karma points
    Apr 19, 2011 @ 20:52
    Swapnil Singha
    Custom 404 page not working and gives a blank page
    I have trying to get custoom 404 page not work functionality working, but on a invalid url its just returning a blank page in google chrome.I read the previous posts on the this topic and made the following changes in web.config
    in system.webserver
    I added the following lines
    <httpErrors errorMode="Custom">
           <remove statusCode="404" subStatusCode="-1" />
           <error statusCode="404" prefixLanguageFilePath="" path="/non-existing-page.aspx" responseMode="ExecuteURL" />
    </httpErrors>
    also  <customErrors mode="On">
    and in umbracoSettings.config,I have set the error 404 tag id of the error page.
    Am I missing something?
    Apr 19, 2011 @ 21:53
    Hi Swapnil
    Have you created the 404 page in Umbraco or is it a page outside of Umbraco?
    If it's created in Umbraco are you then sure the document type it's based on has a template attached to it? And that it has been published?
    Apr 19, 2011 @ 22:25
    Swapnil Singha
    Hi Jan,
    The error page is created in Umbraco.Also a template and document type is attached to it.It has been published too.
    Apr 19, 2011 @ 22:45
    Swapnil Singha
    Hi Jan,
    One correction I need to make in the orginal post and that is
    in IE it gives the error
    The webpage cannot be found
    in mozilla firefox-blank page
    in google chrome - Oops! This link appears to be broken.
  • Giorgos Grispos 145 posts 179 karma points
    Sep 28, 2011 @ 12:16
    Giorgos Grispos
    Hi Swapnil,
    I got the same problem, any udate for the post?
    Have you managed to set up a custom error page. Just to mention that I also have the ASP.NET Security Vulnerability Patch paclage installed.
    Thanks, Giorgos
