  • sachin 22 posts 41 karma points
    Apr 20, 2011 @ 12:25
    sachin
    Captcha in umbraco
    hello There,
    I want to know how to use captcha in umbraco.
    I have create an user control and it contains captcha but i dont know where i should have to place captcha file in umbraco folder.
  • Pasang Tamang 258 posts 458 karma points
    Apr 20, 2011 @ 12:33
    Pasang Tamang
    Place your usercontrol in usercontrol folder and dll of that usercontrol to bin. Other files if your reference files of captcha is in captchafiles folder (in your solution file) then create a captchafiles folder within umbraco and copy all the required files in this folder.
    Pnima
    Apr 20, 2011 @ 12:37
    sachin
    Thanks for reply pasanq but i have  image.aspx file and randomImage.cs file for captcha where should i put these files.
    Apr 20, 2011 @ 12:45
    Pasang Tamang
    How you are using image.aspx in your site? please describe little bit more. If you have create a web application in your solutin then you don't need to place randomImage.cs, just place the dll files. If not try to place it in app code folder.
    Pnima
    Apr 20, 2011 @ 12:51
    sachin
    would you plz give me your email id.i can send you my solution.i am new in umbraco
    Apr 20, 2011 @ 12:53
    Pasang Tamang
    of course why not buddhistsoul@gmail.com
    or you can have a look on this project also http://our.umbraco.org/projects/backoffice-extensions/eyecatch-recaptcha
    Pnima
    Apr 20, 2011 @ 13:01
    sachin
    Thanks pasanq i have sent email.plz check.
