do you need to do anything specfic to get tinymce to do right to left languages like arabic / hebrew?
Regards
Ismail
go to config file tinyMceConfig.config add this to the plugins
<plugin loadOnFrontend="false">directionality</plugin>
<config key="directionality">rtl</config>
add this to you commands
<command> <umbracoAlias>ltr</umbracoAlias> <icon>images/editor/ltr.gif</icon> <tinyMceCommand value="" userInterface="false" frontendCommand="ltr">ltr</tinyMceCommand> <priority>76</priority> </command> <command> <umbracoAlias>rtl</umbracoAlias> <icon>images/editor/rtl.gif</icon> <tinyMceCommand value="" userInterface="false" frontendCommand="rtl">rtl</tinyMceCommand> <priority>77</priority> </command>
add this images to your umbraco\images\editor directory: now you can align the text as you wish
How about adjusting this trick to allow for multi-language site with mixed rtl and ltr languages? with your setting it's either one.
how to get rtl with tinymce
Regards
Ismail
2nd: and this the custom configspecial bonus:
