  • Robert Oswald 72 posts 24 karma points
    Mar 22, 2009 @ 03:28
    Robert Oswald
    Choose style with "[element].[class]" instead of just "[element]" or ".[class]"
    is it possible to create a style property for the RTE that is a little more complex than just:
    [quote]Uses CSS syntax ex: h1, .redHeader, .blueTex[/quote]
    for example, i want to use:
    [code]h1.first[/code]
    but if i choose this style in the RTE no change is applied to the html... so it's not working?
    i have only little hope that there's a solution for this... at least it would be nice for one of the next versions.
    so long, robert
  • Yannick Smits 321 posts 718 karma points
    Dec 14, 2010 @ 14:51
    Yannick Smits
    Have you created a request in codeplex already?
    In the meantime you could try to override the initialization in javascript:
    http://wiki.moxiecode.com/index.php/TinyMCE:Configuration/style_formats
