  • Connie DeCinko 931 posts 1160 karma points
    Apr 21, 2011 @ 19:07
    Connie DeCinko
    Pass URL variable to iframe
    I am passing an URL variable from one Umbraco page to another.  I need to then pass that optional URL variable to an iframe in the target Umbraco page.  The iframe is inside a macro that contains an XSLT snippet.  How can I pass the URL variable to the macro?
    Apr 21, 2011 @ 19:38
    Hi Connie
    Would it be possible to add a macro parameter where the url could be stored and then fetched in the XSLT snippet?
    Apr 21, 2011 @ 19:41
    Connie DeCinko
    We're thinking the same, I'm just not sure how to fetch the variable in the XSLT.  It would have to get the variable of the parent/container page.
    Apr 21, 2011 @ 19:46
    Connie DeCinko
    Could this work?
    <Iframe src="displayframe.asp?<%= request.querystring%>"></iframe>
    Apr 21, 2011 @ 19:50
    Inside XSLT? No...then it would need to look like this...
    <iframe src="displayframe.asp?parameter={umbraco.library:Request('querystring')}"></iframe>
    But if you store the value in a macro parameter you should be able to fetch it by declaring a parameter like this
    <xsl:param name="iframeParameter" select="/macro/YourParameterAlias" /> where "YourParameterAlias" is the alias you have speficied on the macro parameter.
    Apr 21, 2011 @ 20:46
    Connie DeCinko
    Oh, I'm thinking about this wrong.  The macro and XSLT are actually running as part of the Umbraco page, so would have access to the querystring.
    <xsl:param name="qryString" select="umbraco.library:RequestServerVariables('QUERY_STRING')" />
    <iframe src="{$iframeSource}?{$qryString}" name="{$iframeName}_iframe"></iframe>
